R56 BOV si Block off plate
Scris: Mar Oct 25, 2011 3:03 am
de klaude
Vand blow off valve si block off plate de la Alta.Sunt noi.Nu stiu cat sa cer pe ele.Daca e cineva interesat sa ma contacteza!
Re: R56 BOV si Block off plate
Scris: Sâm Iun 23, 2012 1:47 pm
de razvi_dinu
ma interesau,dar vroiam sa stiu daca merg si la r53.astept un raspuns.mersi!
Scris: Sâm Iun 23, 2012 3:55 pm
BOV este pentru echiparea cu turbo,la R53 nu are sens.
Textul nu-mi apartine dar zice bine.
I'll try to explain.
Well 1st off, we need to know why a turbocharged car needs one. As we know, a turbo spins from spend exhaust gas, and will spin down freely if the exhaust gas stops. So if a car is generating boost, it all goes in smoothly to the engine. When the throttle plate closes (ex, shifting from 2nd to 3rd) the turbo is still generating boost and effectively hits a wall, and is forced to go backwards, into the turbo impeller, causing it to slow down or even backspin. Then when you apply throttle again, the turbo has to take the time to change direction again, and build boost again. The BOV is placed in between the throttle plate and the turbo, so that when the throttle plate if closed, the BOV opens, and all the air is let out through it, and not back to the turbo, keeping the turbo moving, allowing you to build boost much faster at the next shift.
Now, why don't we need one? Unlike a turbo, superchargers are connected directly to the engine. Meaning that as soon as we let off the gas to shift, the s/c spins down with it, and then spin right back up as soon as we're back on. Basically, the charged air that a turbo has to deal with between shifts is not there for us, and the little that there is there, is dealt with by our inter bypass valve (connects pre and post s/c). I hope that clears everything up."
Scris: Sâm Iun 23, 2012 6:06 pm
adica cu alte cuvinte BOV (blow off valve) elibereaza presiunea din turbina, pe care R53 nu o are
Scris: Sâm Iun 23, 2012 6:45 pm
Exact, dar am vazut niste chestii comice ,BOV face un zgomot specific si unii isi monteaza(americani am vazut)un generator de sunet si un difuzor care intra in functiune cand pedala este la fund si face zgomotul acela specific.Ar mai fi o solutie sa poti folosi BOV la R53,asta de mai jos(sa montezi turbo pe R53).
Scris: Lun Iun 25, 2012 12:19 am
de razvi_dinu
mersi mult pt sfaturi!nu ma pricep foarte tare,dar acum incep sa ma documentez.as vrea sa fac ceva modificari la masina si mai intreb si eu.mersi mult ina odata!
P.S.vroiam sa intreb ce imi recomandati pt kit-ul de admisie???(firma si de unde as putea achizitiona)
Scris: Lun Iun 25, 2012 12:28 am
multe lucruri deja s-au mai discutat pe forum, incearca sa citesti. daca nu gasesti raspunsurile, deschide un topic al tau si veti discuta acolo, lasati omul sa-si vanda piesa
Scris: Lun Iul 16, 2012 12:00 pm
de coop
eram io interesat da nu merge pe KONA din pacate
Scris: Lun Iul 16, 2012 12:16 pm
merge fane, daca ti-o bagi in cur
Scris: Joi Oct 25, 2012 4:15 pm
de flaviucostea
salut . mai este de actualitate anuntul??
