Before the dealership changed the crankshaft sensor was there a DTC indicating that the crank sensor had an intermittent failure? If not, then the dealership doesn't know how to use their scan tools correctly. Next you need to check to see if the your Mini is having its fuel supply interrupted. You need to check for fuel pressure immediately after the Mini stops running. A defect in the fuel pump itself or the fuel pump relay opening could cause the problem that you are experiencing. I had a Porsche 944 turbo S fuel pump that would jam intermittently causing the car to stop running under all types of different conditions and temperatures until the pump finally quit for good at 2:00 AM. We cut the fuel pump apart and found a small part of weld splatter stuck in the pump rotors that bounced around until it finally lodged in one pump rotor and stalled the pump for good.
motorul se opreste de unul singur
Re: motorul se opreste de unul singur
Vali citeste asta. Este raspuns la problema ta. Si da ii face de kkt pe aia de la Bavaria!
Vorba lui Florin Piersic: LOAZE!
Flash news
Masina nu este gata
Dar mi-au dat o alta masina la schimb
O garsionera pe patru roti
Un Land Rover Freelander 2 aproape nou(9700 km la bord)
O bila alba pentru Bavaria
Glumeam!Vali Iovi scrie:MerciDar nu sunt genul...
Au mai zis ceva ce ar putea sa aiba ?
Hopa. Dar ce schimbare de atitudine din partea lor. Tot nu imi surade ideea ca trebuie sa platesti pt ceva ce in mod clar ei au facut gresit, dar asta e ok. Freelander ... ceva unchi mai metrosexual de-al Mini-ului
