Ma cam bate gandul...
"This is an Engine Stabilizer for the Minis. Certain model years suffered from poor right hand engine mounts resulting in oil leakage from the bottom. This unit keeps the engine from moving back and forth under acceleration which increases overall power. This laser cut and tig welded part is easily installed in under one hour. Improves shifting and smoothes out idle. Also improves take-off acceleration. You will not have any [NVH] NOISE, VIBRATION or HARSHNESS after installed. The fit is like factory and no adjustments to come loose. "
