Re: Mi s-a ars un bec in bord
Scris: Joi Dec 24, 2009 9:33 pm
la tine o sa vina niste craciunite... nu stiu cat se pricep ele sa repare leduri
myMINI.ro - Comunitatea entuziastilor MINI
https://mymini.ro/myforum/
Nu cred ca este easy fix si ma gandesc sa cumpar un panou intreg.If you were to turn it back beyond zero while the black fascia is removed you would find that a ball bearing flies out and you would more than likely end up squashing a spring. Two ball bearings and a spring provide the "notchiness" for the blower control. I managed to recover the situation by cutting the spring and stretching it to the required length after spending a considerable amount of time scouring the floor for the missing ball bearing.
