Hendrix
- Grosos Antonio
Hendrix
Celalt brit al nostru e un triumph herald 13/60 Convertible din 1969
1969 Triumph Herald 13/60 Convertible
1296 cc
61bhp (almost, some lost on the way during 42years)
4 speed manual
P1000 Pierrelli 12" white metal wheels (as you can see)
Refurbished red vinyl soon will get the proper leather seats
New Soft top
The car was bought in 1987 for 200 pounds as a saloon version and originally grey paint job, been modified and turned into a Convertible in 1988 (some small restoration). Used as a day by day car also as a second car until 1996, sat into the garage till 2008 till the car was sent back to restore to Classic Restoration Scotland ltd. It was there until 2011 September.
On 5th of January the car had his proper outing after about 16 years. And it performed absolutely fantastic ( well, as a British sometimes he needed the chock pulled )
That's it...
Mi-a fost cam lene sa traduc povestioara de pe facebook, dar am incredere in voi ca veti intelege
1296 cc
4 speed manual
New Soft top
That's it...
MINIish
MINIish
- Grosos Antonio
Re: Hendrix
Mai multe detalii
MINIish
MINIish
- Grosos Antonio
Re: Hendrix
MINIish
MINIish
Re: Hendrix
Deci.....felicitari...imi plac si Range-ul si Triumph-ul...eu unul, care incet incet ma dezic de MINI... nu prea inteleg ce cauta MINI in ecuatia asta....
Re: Hendrix
Antonio , imi place la nebunie,ai uitat sa adaugi detalii tehnice pe care le-am dedus din filmulet:
Carburator orizontal,shock actionat manual, ambreiaj actionat hidraulic,are si instalatie de incalzire habitaclu,motorasul de la stergatoare cu ax flexibil este mortal .Am vazut ca iti lipseste scoala de soferi cu Dacia 1300(parca ai avut ceva bâlbe la schimbator). Cand incerci o resoftare sa recuperezi caii pierduti?
Re: Hendrix
e foarte simplu: keep it britishrazvan333 scrie:Deci.....felicitari...imi plac si Range-ul si Triumph-ul...eu unul, care incet incet ma dezic de MINI... nu prea inteleg ce cauta MINI in ecuatia asta....
Re: Hendrix
tu ai ceva atractii catre englezoaice vad
sa le stapanesti sanatos!
Re: Hendrix
cred ca sunt englezoi aia catre care are el atractii... nu vad una cu nume de fata
- Grosos Antonio
Re: Hendrix
Da ba tanasi, sunt atras de nume de oameni puternici...
) Voiai sa ii zic Angla Merkel ?
Si da, imi place industria auto englezeasca desi e detinuta de indieni in mare parte
MINIish
MINIish
- Grosos Antonio
Re: Hendrix
Dupa cum ti-am zis sunt multe care mai trebuie facute, motorul trebuie pur si simplu dat jos desfacut si curatat, Sincer am mers cu el cu 75mph dar am promis sa nu mai fac asa ceva cat traiesc. Problema cu schimbatorul e ca atunci cand treci de pe una moderna pe aia uiti ca schimbatul vitezelor e ceva la care trebuie sa te concentrezi si mai faci cate o buba. Promit sa ma invat...
P.S. eu sunt generatia 1310
adrian scrie:Antonio , imi place la nebunie,ai uitat sa adaugi detalii tehnice pe care le-am dedus din filmulet:
Carburator orizontal,shock actionat manual, ambreiaj actionat hidraulic,are si instalatie de incalzire habitaclu,motorasul de la stergatoare cu ax flexibil este mortal .Am vazut ca iti lipseste scoala de soferi cu Dacia 1300(parca ai avut ceva bâlbe la schimbator). Cand incerci o resoftare sa recuperezi caii pierduti?![]()
MINIish
MINIish
