Piese Mini Cooper R50 1.6 i Benzina an 2004 si Mini Cooper R56 1.6 D, an 2007
Salutare,
Dezmembrez Mini Cooper R50 1.6 i Benzina an 2004 si Mini Cooper R56 1.6 D, an 2007
Orice Piesa; cutie manuala,motor (chiulasa, bloc motor, arbori, pompa ulei, etc) injectoare, pompa injectie, egr, radiatoare, planetare, volanta, ambreiaj, cd - player, jante aliaj/Roti 175/65/R15, elemente caroserie, elemente+ tapiterie interior negru/gri, airbag - uri etc. . .
Seriozitate garantata
Garantez preturi de bun simt
Expediere in tara in maxim 24 h cu plata la destinatie
Piesele sunt de calitate auto nefiind rulate in Romania
Lazar
piston Mini Cooper
biela Mini Cooper
capac motor Mini Cooper
volanta Mini Cooper
ambreiaj kit Mini Cooper
bloc motor Mini Cooper
injectoare Mini Cooper
rampa injectoare Mini Cooper
conducte rampa injectoare Mini Cooper
motor Mini Cooper
cutie sigurante Mini Cooper
calculator motor Mini Cooper
Capac calculator motor Mini Cooper
suport baterie Mini Cooper
cablaj motor Mini Cooper
chiulasa Mini Cooper
culbutor Mini Cooper
ax culbutori Mini Cooper
ax came Mini Cooper
supapa Mini Cooper
pompa ulei Mini Cooper
racitor ulei Mini Cooper
sonda lambda Mini Cooper
racord Mini Cooper
clapeta acceleratie Mini Cooper
arbore cotit Mini Cooper
senzor turatie arbore cotit Mini Cooper
conducta Mini Cooper
pompa injectie Mini Cooper
compresor AC Mini Cooper
conducta AC Mini Cooper
EGR Mini Cooper
turbina Mini Cooper
catalizator Mini Cooper
Tampon motor Mini Cooper
alternator Mini Cooper
intinzator Mini Cooper
electromotor Mini Cooper
radiator AC Mini Cooper
radiator apa Mini Cooper
intercooler Mini Cooper
electroventilator Mini Cooper
vacuum Mini Cooper
vas expansiune Mini Cooper
vas lichid parbriz Mini Cooper
filtru aer Mini Cooper
debitmetru Mini Cooper
cutie viteze Mini Cooper
furtun ambreiaj Mini Cooper
pompa ambreiaj Mini Cooper
distribuitor frana Mini Cooper
pompa frana Mini Cooper
Tulumba Mini Cooper
Vas lichid frana Mini Cooper
claxon Mini Cooper
Vas lichid servo Mini Cooper
Pompa servodirectie Mini Cooper
ax volan Mini Cooper
far stanga Mini Cooper
carenaj fata Mini Cooper
brat fata Mini Cooper
aripa fata Mini Cooper
parbriz Mini Cooper
bara fata Mini Cooper
far dreapta Mini Cooper
proiector Mini Cooper
grila bara Mini Cooper
masca crom Mini Cooper
armatura fata Mini Cooper
cot tubulatura Mini Cooper
emblema Mini Cooper
capota Mini Cooper
balama capota Mini Cooper
amortizor capota Mini Cooper
incuietoare capota fata Mini Cooper
tija capota Mini Cooper
overfender Mini Cooper
motoras stergatoare Mini Cooper
cheder capota Mini Cooper
planetara stanga Mini Cooper
planetara dreapta Mini Cooper
bara stabilizatoare fata Mini Cooper
arc Mini Cooper
amortizor fata Mini Cooper
etrier fata Mini Cooper
disc frana fata Mini Cooper
fuzeta fata Mini Cooper
senzor ABS Mini Cooper
lonjeron fata Mini Cooper
contraaripa fata Mini Cooper
antifurt roata Mini Cooper
prezon Mini Cooper
jante aliaj Mini Cooper
nuca schimbator viteze Mini Cooper
pedala frana Mini Cooper
pedala ambreiaj Mini Cooper
pedala acceleratie Mini Cooper
volan piele Mini Cooper
inel colector volan Mini Cooper
air bag volan Mini Cooper
air bag pasager Mini Cooper
air bag cortina Mini Cooper
cd player Mini Cooper
consola Mini Cooper
bloc lumini Mini Cooper
consola ceasuri Mini Cooper
afisaj bord Mini Cooper
buton Mini Cooper
Bricheta Mini Cooper
parasolar Mini Cooper
maner plafon Mini Cooper
centura fata Mini Cooper
pretensioner centura Mini Cooper
centura spate Mini Cooper
scaun fata Mini Cooper
tetiera scaun Mini Cooper
cotiera Mini Cooper
bancheta Mini Cooper
oglinda Mini Cooper
geam spate Mini Cooper
cupola Mini Cooper
cablu frana mana Mini Cooper
portiera fata Mini Cooper
balama portiera Mini Cooper
opritor portiera Mini Cooper
bandou portiera Mini Cooper
maner portiera Mini Cooper
panou interior portiera Mini Cooper
difuzor portiera Mini Cooper
geam portiera Mini Cooper
macara geam Mini Cooper
motoras geam Mini Cooper
incuietoare portiera Mini Cooper
cheder portiera Mini Cooper
prag dreapta Mini Cooper
scut podea Mini Cooper
prag stanga Mini Cooper
portiera spate Mini Cooper
antena Mini Cooper
bara spate Mini Cooper
armatura bara spate Mini Cooper
lampa Tripla spate Mini Cooper
carenaj spate Mini Cooper
aripa spate Mini Cooper
fuzeta spate Mini Cooper
brat spate Mini Cooper
disc frana spate Mini Cooper
etrier spate Mini Cooper
amortizor spate Mini Cooper
punte spate Mini Cooper
catadioptru Mini Cooper
luneta Mini Cooper
haion Mini Cooper
maner haion Mini Cooper
incuietoare haion Mini Cooper
emblema spate Mini Cooper
scris spate Mini Cooper
rezervor carburant Mini Cooper
capac rezervor Mini Cooper
clapeta rezervor Mini Cooper
pompa combustibil Mini Cooper
panou spate Mini Cooper
podea portbagaj Mini Cooper
toba esapament Mini Cooper
roata rezerva Mini Cooper
cric Mini Cooper
balama haion Mini Cooper
amortizor haion Mini Cooper
cheder haion Mini Cooper
spoiler Haion Mini Cooper
inchizator pe capota Mini Cooper
inchizator capota pe trager Mini Cooper
protectie panou fata Mini Cooper
Ornament tripla spate dr Mini Cooper
ornament stalp spate dr. Mini Cooper
calculator motor DDE Mini Cooper
calculator airbag Mini Cooper
panou comanda plafon Mini Cooper
ventilator habitaclu Mini Cooper
incalzitor suplimentar habitaclu Mini Cooper
Panou comanda AC Mini Cooper
Modul electronic PDC Mini Cooper
Mini Cooper
Modul electronic CAS Mini Cooper
Calculator Acces Mini Cooper
Bujie incandescenta Mini Cooper
Pompa Vacuum Mini Cooper
Regulator Presiune Vacuum Mini Cooper
Galerie Evacuare Mini Cooper
Senzor arbore cotit impulsuri Mini Cooper
filtru combustibil Mini Cooper
preincalzitor filtru comb Mini Cooper
pinion pompa inalta presiune/injectie Mini Cooper
injector Mini Cooper
conducta alimentare injector Mini Cooper
conducta alimentare combustibil Mini Cooper
Suport motor dr. sprijin Mini Cooper
suport motor central Mini Cooper
panou interior portiera cu accesorii Mini Cooper
Lazar
piston Mini Cooper
biela Mini Cooper
volanta Mini Cooper
motor Mini Cooper
ax came Mini Cooper
supapa Mini Cooper
racord Mini Cooper
EGR Mini Cooper
turbina Mini Cooper
vacuum Mini Cooper
Tulumba Mini Cooper
claxon Mini Cooper
parbriz Mini Cooper
emblema Mini Cooper
capota Mini Cooper
arc Mini Cooper
prezon Mini Cooper
consola Mini Cooper
buton Mini Cooper
cotiera Mini Cooper
oglinda Mini Cooper
cupola Mini Cooper
antena Mini Cooper
luneta Mini Cooper
haion Mini Cooper
cric Mini Cooper
Mini Cooper
Ultima oară modificat Lun Sep 11, 2017 11:54 am de către gyovani19, modificat de 15 ori în total.
Dezmembrez Mini Cooper R56 1.6 D, an 2007 si Mini Cooper ONE R50 1.6 i Benzina an 2004
Gyovani 0731615104
http://www.mymini.ro/myforum/viewtopic.php?f=27&t=2563
Gyovani 0731615104
Re: Dezmembrez Mini Cooper D, 1560 diesel R56,an 2007, manua
Un pret te rog pentru oglinda stanga si nuca schimbator.
Multumesc!
Multumesc!
Salutarecris1805 scrie:Salut,
Multumesc!
Ambele 400 lei, m-am gandit sa fie un pret de bun simt
piesele arata impecabil
Toate cele bune
Gyovani 0731615104
Gyovani 0731615104
Un pret separat pentru nuca schimbator. Multumesc!
Re: Dezmembrez Mini Cooper D R56,an 2007, 1560 diesel, manua
Masina are volanul pe dreapta,oglinzile nu se potrivesc,nu numai sticla difera,piciorul oglinzii este orientat altfel pentru volan stg. sau dreapta,daca pui oglinda asta la tine pe masina nu vei vedea nimic in ea.
Salut,adrian scrie:Masina are volanul pe dreapta,oglinzile nu se potrivesc,nu numai sticla difera,piciorul oglinzii este orientat altfel pentru volan stg. sau dreapta,daca pui oglinda asta la tine pe masina nu vei vedea nimic in ea.
teoretic nu ar trebui sa fie o problema
Sa inteleg ca suportul oglinzii este diferit?
Este o parere sau ati constat fizic acest aspect?
Multumesc
PS: Ma intereseaza direct, pentru a nu ajungein situatia sa trimit cuiva o piesa care nu se potriveste..
Ultima oară modificat Vin Feb 19, 2016 2:49 pm de către gyovani19, modificat 1 dată în total.
Gyovani 0731615104
Gyovani 0731615104
Am constatat fizic, te asigur, lucrez cu piese de la dezmembrari de Anglia de 10 ani.Cateva grade diferenta si te scoate din campul vizual.gyovani19 scrie:Salut,adrian scrie:Masina are volanul pe dreapta,oglinzile nu se potrivesc,nu numai sticla difera,piciorul oglinzii este orientat altfel pentru volan stg. sau dreapta,daca pui oglinda asta la tine pe masina nu vei vedea nimic in ea.
Este o parere sau a-ti constat fizic acest aspect?
Multumesc
Re: Dezmembrez Mini Cooper R56,an 2007, 1560 diesel, manual
E prima oara cand dezmembrezi o masina de anglia?
lucrurile astea se stiu... oglinzi... faruri... broaste de usi... incuietori...
Salut,cristi o'RAL scrie:E prima oara cand dezmembrezi o masina de anglia?
Ma mira ce spui de oglinzi, faruri, broaste usi?????? incuietori???????? la ultimele doua nu inteleg... de unde ar proveni diferenta?
Merci oricum de buna intentie
Ultima oară modificat Mie Feb 10, 2016 12:08 am de către gyovani19, modificat 1 dată în total.
Gyovani 0731615104
Gyovani 0731615104
La oglinzi se probeaza usor,urca in stanga si incearca sa reglezi oglinda ,ai sa te convingi singur.
