Cutie automata MINI COOPER 2002
bumbumparty
Re: Cutie automata MINI COOPER 2002
Mesaj de bumbumparty »
apropo de lag...am gasit asta pe youtube...cine stie de unde putem lua...fac comanda cu banii pe loc...!
http://www.youtube.com/watch?v=HrfoEs9epTQ
Nu ai Mini?
Nu existi!
Item G - INTERNAL VALVE BODY HARNESS
Item H - PRIMARY PILOT TUBE
Item I - SECONDARY PRESURE SOLENOID
Item J - SECONDARY SUPPORT BEARING (SMALLER)
Item K - PRIMARY SUPPORT BEARING (LARGER)
Item L - PUMP ASSMEBLY
Item M - STEPPER SOLENOID - See NOTE below
Item N - VALVE BODY ASSEMBLY
Item O - PAN FILTER
Item P - OIL PAN GASKET
Note: Earlier Stepper Solenoids use a Twist-Lock type connector - these solenoids are no longer available. This replacement has a Snap Connector - not the Twist-Lock. There are no functional differences between the new style with the plastic cover and the old style aluminum version, but unfortunately due to the casting design on the early valve bodies, the new solenoid does not fit without some modification to the valve body. On early valve bodies, there is a protrusion on the valve body housing that prevents the solenoid from going all the way into the valve body. This protrusion, which has no functional use, can be safely removed from the aluminum valve body casting, allowing the new style stepper motor to fit fully into the valve body housing.
STEPPER SOLENOID.jpg (6.69 KiB) Vizualizat de 5395 ori
bumbumparty
Nu ai Mini?
Nu existi!
Mesaj de razvan333 »
Buna treaba, de unde naiba procuram si noi sprint boosteru ala? presupun ca din State :mrgreen:
Sa faca oare treaba asa buna cablul ala?
bumbumparty
Vali iovi...si pentru cei ce nu stiu engleza?:)) ce trebuie sa vedem aici? item .... fire ce-i cu astea?
Nu ai Mini?
Nu existi!
bumbumparty
uite am gasit...cine stie sa cumpere chestii de pe net? :) http://www.sprintboostersales.com/
Nu ai Mini?
Nu existi!
bumbumparty scrie:Vali iovi...si pentru cei ce nu stiu engleza?:)) ce trebuie sa vedem aici? item .... fire ce-i cu astea?
Google translation :D
bumbumparty
nu serios ce e cu alea...! uite razvan333 am gasit aici... daca imi spui tu cat costa ... :) http://new.minimania.com/web/Item/SPR20 ... Detail.cfm
Nu ai Mini?
Nu existi!
Asta caut. :D Are cine la noi pe forum pus. :D
bumbumparty
haide ca nu degeaba scrie sus deasupra capului tau... site admin :)
Nu ai Mini?
Nu existi!
