Cutie automata MINI COOPER 2002
- bumbumparty
- Viteza 2
Re: Cutie automata MINI COOPER 2002
apropo de lag...am gasit asta pe youtube...cine stie de unde putem lua...fac comanda cu banii pe loc...!
http://www.youtube.com/watch?v=HrfoEs9epTQ
Nu ai Mini?
Nu existi!
Nu existi!
Item G - INTERNAL VALVE BODY HARNESS
Item H - PRIMARY PILOT TUBE
Item I - SECONDARY PRESURE SOLENOID
Item J - SECONDARY SUPPORT BEARING (SMALLER)
Item K - PRIMARY SUPPORT BEARING (LARGER)
Item L - PUMP ASSMEBLY
Item M - STEPPER SOLENOID - See NOTE below
Item N - VALVE BODY ASSEMBLY
Item O - PAN FILTER
Item P - OIL PAN GASKET
Note: Earlier Stepper Solenoids use a Twist-Lock type connector - these solenoids are no longer available. This replacement has a Snap Connector - not the Twist-Lock. There are no functional differences between the new style with the plastic cover and the old style aluminum version, but unfortunately due to the casting design on the early valve bodies, the new solenoid does not fit without some modification to the valve body. On early valve bodies, there is a protrusion on the valve body housing that prevents the solenoid from going all the way into the valve body. This protrusion, which has no functional use, can be safely removed from the aluminum valve body casting, allowing the new style stepper motor to fit fully into the valve body housing.
Item O - PAN FILTER
- Fişiere ataşate
- STEPPER SOLENOID.jpg (6.69 KiB) Vizualizat de 5386 ori
- nmd5068b.jpg (8.5 KiB) Vizualizat de 5386 ori
- bumbumparty
- Viteza 2
Nu ai Mini?
Nu existi!
Nu existi!
Buna treaba, de unde naiba procuram si noi sprint boosteru ala? presupun ca din State
Sa faca oare treaba asa buna cablul ala?
- bumbumparty
- Viteza 2
Vali iovi...si pentru cei ce nu stiu engleza?:)) ce trebuie sa vedem aici? item .... fire ce-i cu astea?
Nu ai Mini?
Nu existi!
Nu existi!
- bumbumparty
- Viteza 2
uite am gasit...cine stie sa cumpere chestii de pe net?
http://www.sprintboostersales.com/
Nu ai Mini?
Nu existi!
Nu existi!
Google translationbumbumparty scrie:Vali iovi...si pentru cei ce nu stiu engleza?:)) ce trebuie sa vedem aici? item .... fire ce-i cu astea?
- bumbumparty
- Viteza 2
nu serios ce e cu alea...! uite razvan333 am gasit aici... daca imi spui tu cat costa ...
http://new.minimania.com/web/Item/SPR20 ... Detail.cfm
Nu ai Mini?
Nu existi!
Nu existi!
- bumbumparty
- Viteza 2
haide ca nu degeaba scrie sus deasupra capului tau... site admin
Nu ai Mini?
Nu existi!
Nu existi!
