Se pare ca adrian avea dreptate.
Citeam gresit joja. Cumpar ulei si va tin la curent.
Explicatia cum poti citii joja gresit si solutia :
The most important thing to understand when using an OEM Mini dipstick is that the bottom bulb, if re-inserted into the oil pan will draw oil up into the tube when withdrawn.
The trick is after first removing the dipstick, re-insert it into the tube but not far enough to get oil on the bottom bulb.
You do this several times, cleaning the oil off each time, until the tube is clean of excessive oil.
After cleaning the tube of excess oil you can then re-insert the dipstick fully into the oil pan, withdraw it and read the level.
If you keep the OEM dipstick, the best thing you can do is remove that bottom bulb so it will not draw oil up into the tube in the first place.
Un alt model de joja :
http://www.cravenspeed.com/mini-dipstick/
